will an 89 5.7 &ecm work with a 91tranny?
Old Dec 21, 2000 | 08:36 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
i'm going to be swapping my 305 tbi for a 350 tpi.my car is a 91 bird with an 4L60e(electronic)tranny(700r4).the motor i'm putting in is from a 89 bird.what year did gm switch over to a electronic tranny from a non-electronic(4L60)?i bought the motor,harness and ecm w/chip.
1991 banditt2 firebird #130of#600
Old Dec 22, 2000 | 01:21 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
93 was the last year for the non-electronic 700R4/4L60. You're saying you have a 4L60E in your 91? Or you have a 4L60?
You can use any non-electronic trans with a TPI computer, since the only thing it controls is the torque converter lockup. That is built into the PROM.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Dec 22, 2000 | 06:11 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I think you are confusing the TCC Lockup function as being "electric tranny". Both the '89 and '91 have a regular 4L60 and the swap will be OK.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass,
SSM SFC, Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Dec 22, 2000 | 06:41 AM
91banditt2's Avatar
Engine: 5.7 HSR
the tranny is the stock tranny!i thought i read some where that 91 was the first year for the 4L60E?
Old Dec 22, 2000 | 12:14 PM
Kevin91Z's Avatar
Nope, 94 is the first year for the 4L60E. In 1990, GM changed the name of the trans from 700R4 to 4L60, but its the exact same trans. In 1994, it was changed to electronically controlled shifting, and given the name 4L60E.
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
89gtaforsale
Aug 24, 2015 09:32 PM
jharrison5
Aug 19, 2015 05:53 PM
Fronzizzle
Aug 17, 2015 02:52 PM
