not shifting out of first gear
Old Dec 22, 2000 | 02:55 PM
swinsbird's Avatar
Here's the scoop, the other day I got stuck comming up my drive way. I put it in first gear and the car got unstuck and went on up the driveway fine. But now when I drive it, it won't shift into second gear. Could my linkage be messed up. My fluid was low but I filled it up, and it didn't seem to help any.
Travis,
90 firebird 305 tpi
th700r4
Old Dec 22, 2000 | 03:07 PM
Blade's Avatar
Well there's several thing that might have gone wrong. Most then likely it has something to do with your governor though. I'd say pull it out and check whether the gear has broken off, or the teeth on it are too worn. It also might have gotten stuck somehow.
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Check out TruSpeed at http://www.truspeed.org
Check out the Bin Archive at http://www.truspeed.org/bins.html
Old Dec 22, 2000 | 09:31 PM
82z's Avatar
82z
Will it shift into the other gears manually. If it does then you have a governor problem if not you are sol. Do you have any other gears? How fast have you driven it in 1st? It is possible however unlikely that your throttle pressure is way high. Maybe the tv got stuck in the wot position. That is way out there though. Check the governor first.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
TheTraut88
Sep 11, 2015 05:16 AM
GouldyGTR
Sep 7, 2015 09:05 PM
TheTraut88
Sep 7, 2015 05:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
tonys91rs
Sep 2, 2015 07:07 PM
