How do you shift a 4L60 into gear???
Old Dec 20, 2000 | 07:12 AM
Black Missile's Avatar
That is without making it bump forward when shifting into reverse gear.
Since all other gears including park shift smoothly when manually selected, what is causing this bump or lurch when I select reverse gear?
Would a bad reverse gear boost valve be the problem? If so, where in the trans is it located?
1989 Firebird GTA: black on black 5.7 liter (N10 dual exhaust) with T-tops and leather.
Old Dec 20, 2000 | 11:18 PM
ttt
Old Dec 22, 2000 | 10:07 PM
82z's Avatar
82z
That is most often caused by too high line pressure when reverse is selected. The cause would be the reverse boost valve. It is located on top(?) of the pressure regulator valve in the pump. Major PITA to fix. I would live with it.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
tonys91rs
Sep 2, 2015 07:07 PM
