700R4 confusion
Old Sep 8, 2008 | 10:58 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
700R4 confusion
ok let me start off by saying I'm not an expert with transmissions, especially automatics... but I do know I'm having a problem.
vehcile: 1991 Camaro Z28 350 5.7L 700R4 3:08 Rear Gears.
Taking off from a stop it drives and shifts normally through 4 gears and seems normal. However crusing at 80km/h (50MPH) in OD this car holds at a constant 2400rpm which seems awefully high to me.
In comparison, my IROC with a 5 speed and 3:45 rear gears cruises at 1200rpm at the same 80km/h.
Is the torque converter not locking up, or what could possibly be the problem? What can I check or look into?
Any help would be appreciated, thank you.
Old Sep 8, 2008 | 11:16 PM
irocdave12's Avatar
Car: 87 IROC-Z Camaro
Axle/Gears: Strange S60 Dana 3:73
Re: 700R4 confusion
Sounds like your maybe on the right track. I have a toggle switch that controls my converter lock up and the rpm u stated is about where mine runs at also when I have switch off. Check the square white plug down at trans for damage or if its even plugged in first
Old Sep 8, 2008 | 11:50 PM
Brisk's Avatar
Re: 700R4 confusion
ok thanks, I'll check into that first thing in the morning.
Old Sep 8, 2008 | 11:54 PM
irocdave12's Avatar
Re: 700R4 confusion
I put my switch in cause if you wanna get it on with someone you dont want your converter coming in at 35 mph and killing your acceleration. TCI tranny compnay even recommeneds it as option with trans they sell so its ok to do just wanna def use on highway so not to overheat tranny but stop and go driving the converter really takes away from the cars fun
Old Sep 9, 2008 | 12:14 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 700R4 confusion
It won't if everything is working properly. The ECM will unlock the TCC under low vacuum and high throttle opening.
Old Sep 9, 2008 | 12:19 AM
irocdave12's Avatar
Re: 700R4 confusion
the converter unlocks also when u apply the brakes and is how TCI tells you to over ride its function by installing a switch there by tricking the ecm into thinking the brake is always applied until u turn the switch off returning normal operation
Old Sep 9, 2008 | 02:05 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 700R4 confusion
That's now how it works. The ECM doesn't know when the brakes are applied. The brake switch interrupts the +12v source to the TCC solenoid directly.
Regardless, you don't need it if your ECM is working.
Old Sep 9, 2008 | 02:54 PM
Brisk's Avatar
Re: 700R4 confusion
ok I have two plug-ins on the tranny that I can see, neither are white. One is a three wire plug near the shifter linkage on the drivers side, and one two wire plugin at the tail end of the transmission.
both plugs are in and appear to be in decent condition. looks like I'll have to dig in my shop manual and see what information is in there.
any other advice?
Old Sep 9, 2008 | 03:11 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 700R4 confusion
The 3 wire plug (with 4 "prongs" if you unplug it) is the TCC connector.
Are you sure your tach is accurate?
Old Sep 9, 2008 | 04:07 PM
Brisk's Avatar
Re: 700R4 confusion
no I am not sure my tach is accurate, but a problem certinally exists. I can drive my heavily modded 5.0L 5-speed IROC to work and back 4 days on a 1/4 tank of gas, and my stock 5.7L 700R4 will burn 1/4 tank of gas in one day.
I realize the gas tanks may be different sizes, however they both cost approximatly the same amount to fill up.
Old Sep 29, 2008 | 10:58 PM
Brisk's Avatar
Re: 700R4 confusion
ok I just thought I'd come back and update this...
I found a leaking vacuum hose and replaced it, the tranny now shifts properly. I also found my tach is very inaccurate, VERY. Lastly I reset the timing, which was set to 0.. I've now got it set to approximatly 7deg and it runs much better.
With the above problems resolved, the gas milage has greatly improved - as well as increased performance.
Old Sep 30, 2008 | 07:54 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: 700R4 confusion
A quick check is while in OD you should read 1000 rpm's @ 40MPH.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
