Converter question (is the mechanic right)
Old Sep 8, 2008 | 11:01 PM
sweetaq's Avatar
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
So I bought a converter froma guy on ebay and my have gotten screwed. He says it is a alabama converter stall but it is purple like a precision industries. My trans mechanic looked at today while I dropped off my trans that he rolled or pinched the front pump seal on. He said it could be bad but isn't sure because it may be spragless. He stuck his finger down inside it and turned the splined part in both directions. He said if it is a sprag its f'ed but it my be a spragless. Will it turn in both directions if it is spragless or should it still only go in one direction? It should still have a overrun clutch right? The guy I bought it from says he can't remember if it is spragless or not but swears it worked great for him...imagine that. Its for a th350 by the way
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
redmaroz
Aug 16, 2015 11:40 PM
gwade12
Aug 8, 2015 08:17 AM
