elec speedo & T56
Car: C1500
elec speedo & T56
I found this here http://www.skulte.com/T56.html
"The two areas that will be a little messy are fabricating a transmission crossmember, and using the electronic speed signal. If you have a 90+ Camaro or an 87+ Firebird you already have an electronically driven speedometer."
I posted before asking when electronically driven speedos came out instead of cable driven. I got the reply of '90, so what is right? Could it be cable or electric , was it an option?
Is a 4th gen driveshaft the same length as a 700R4/T-5 third gen driveshaft?
Oh one more thing, of someone wants to swap to a T56 why can't they use the crossmember off of a 4thgen donor car?
1985 Camaro IROC-Z LB9
1989 Pontiac Firebird
Formula W6S LO3 TBI 305
-180 degree stat
-Hooker Cat-Back
[This message has been edited by Keith5 (edited December 29, 2000).]
-180 degree stat
-Hooker Cat-Back
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The article is correct. Electronic speedos came out in all 1990+ cars for Camaros, and all 1987+ cars for Firebirds.
Yes the driveshafts are the same length and are interchangable.
The shape of the 4th gen crossmember is different and wont fit the thirdgen frame.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Car: C1500
D7C : GEAR, SPEEDO DRIVEN
D9A : SENSOR, VEH SPD
E5Z : SPEEDOMETER ADAPTER (DELETE)
E9Z : SPEEDOMETER KEY (DELETE)
These are from my '89 Formula. What do they mean?
-180 degree stat
-Hooker Cat-Back
-180 degree stat
-Hooker Cat-Back
bigjay89gta
Oct 15, 2015 08:04 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
