Another question about correcting the speedo for a gear swap...
To switch the speedo gears to correct the speedometer reading when the rear gears are changed, do you need to pull the speedometer cluster or is all the work done down by the transmission (where is the driven gear located, behind the speedometer or off of the transmission)?
All the work is done on the tranny. The driven gear is on the back of the tranny (drivers side) and is held on by one bolt and a bracket. Just unbolt it and swap the gear, that's it.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI,700R4, Trick Flow Heads, Comp Cam, Comp 1.6 Rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, gutted cat, Mallory coil, Mallory HyFire IV ignition box, Mallory Sidewinder 8mm wires, Autolite platinum plugs, K&N filters, Transgo Performance Shift Kit, Corvette Servo, 2,000 Torque Converter
bsa
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
On an automatic trans its easy, both gears are accessible. But on a T5, you have to drop the trans to get at the drive gear. If you just have to change the driven gear, its easy.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
beachrodder
Aug 7, 2015 04:27 PM
