Went from 2.77 to 3.23.
Old Dec 30, 2000 | 10:15 PM
BP89IROC's Avatar
What gears do I nead for my speedo now. I would like to only have to change the driven gear. Its a 89 tpi 350 with a 145 speedo and 700 r4.
1989 Iroc-Z TPI 350 auto 4-spd Removed MAF screens K & N filters, stock other than that.
Old Dec 31, 2000 | 12:29 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You will need to add 3 teeth to your driven gear (ie. if you have 35 teeth you will need 38) etc. However if adding 3 puts you over 40 teeth on the driven gear you also have to change the housing (or sleeve as they call it) because it has the be offcenter for any no. over 39.
ChevyLuva3
Dec 5, 2001 08:50 AM
KeithO
Oct 1, 2001 12:47 PM
89IROC5.7
Aug 31, 2001 12:14 PM
89 Iroc Z
Aug 29, 2001 11:27 AM
JeffD89Iroc
Oct 13, 2000 07:49 AM
