Now Ring Gear Confusion!
Old Sep 11, 2008 | 12:14 PM
Hello, Michael's Avatar
Car: 1987 Pontiac Firebird Trans Am WS6
Engine: SBC 350
Axle/Gears: 3.70:1 BW M78 9-Bolt Posi
My 87 Trans Am has a 2.77 axle ratio. I'm hearing that this is a 9-Bolt carrier (Series 2). I'm planning on ordering a 3.73 gear set, but I don't see anything on Jegs about a 9-Bolt. I see the gear set for the Series 2 carrier and Series 3 carrier. It states that Series 2 is 3.08 and lower carrier, and Series 3 is 3.23 and higer carrier. So, do i have a 9 or 10 bolt carrier?!!
Old Sep 11, 2008 | 12:23 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Now Ring Gear Confusion!
Crawl under the car and count the bolts. Should you have a 9-bolt, finding parts may be difficult. Check the following link for a ton of info:
https://www.thirdgen.org/forums/faq-...now-about.html
JamesC
Old Sep 11, 2008 | 01:56 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
2:77 gear ratio is from a BW 9-bolt rear and you will find very few replacement parts. Most everything from a Autoparts suppliers are for 10-bolts and the part are NOT interchangeable. Example: 9-bolt ring gear 7.750 dia vs 10-bolt ring gear 7.5/.625 dia.
Old Sep 12, 2008 | 08:29 AM
Engine: SBC 350
Right, I know they're not interchangeable. Will an aftermarket 10-bolt carrier work with the BW housing?
Old Sep 12, 2008 | 11:06 AM
DJP87Z28's Avatar
One big NO... .nothing and I mean nothing is interchanable.
GTAman
Jul 3, 2024 07:29 PM
Jorlain
Oct 8, 2015 01:57 AM
IROCtometal
Sep 9, 2015 10:01 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
