Not shifting properly
Subscribe
Dec 30, 2000 | 07:25 PM
On my 91 RS when I floor it on open road sometimes it will go all the way top the red line and stay there until i let off the gas then it will shift. What is wrong?
Mike Kenny
Current: 1991 RS 305 TBI
Past: 1990 RS 305 TBI (A woman forgot what red lights are for)
Current: mostly stock - newer 305 w/ 12,000 on it
Eclipse speakers all around w/ 10" tube powered by a Alpine V12 in back
K&N filter w/XStream flow lid - It is sweet!!
Future: 2" Cowl hood
Reply 0
Dec 30, 2000 | 11:22 PM
Sorry for the bad news but sounds like your clutches are sliping and it is time for a rebuild.
Reply 0
Dec 31, 2000 | 12:31 PM
Is this it? How much would this cost me and how/should I upgrade?
Mike Kenny
Reply 0
Dec 31, 2000 | 02:02 PM
What gear are you in when it does this and what gear are you waiting for it to shift into?
If you are in 3rd gear at WOT and waiting for 4th, it won't happen unless you upgrade your valvebody.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Reply 0
Dec 31, 2000 | 06:49 PM
It usually does, if not always, happens when going from 3rd to 4th. If I upgrade my valve body (how much?) will I still need to have clutch work done. Thanks for the help.
Reply 0
Jan 1, 2001 | 06:39 PM
your problem is most likely in the upshift valve of your valve body. the b&m transpak kit should include all the parts to fix it,
the kit costs around $60 plus you'll need trans fluid
Black 89 Iroc 5.7
355 in. SB
many other mods and more to come
Reply 0
Subscribe
