Rear End Noise
Old Sep 14, 2008 | 01:13 AM
skiroulertx447's Avatar
Car: 86 Z28
Axle/Gears: 3.42 posi
Rear End Noise
I've noticed that the differential in my 86 Z28 makes a wierd noise when accelerating when making a right turn, I thought I read somewhere that that was caused by the clips on the end of the axles being worn, what do you guys think?
Old Sep 14, 2008 | 09:41 AM
big gear head's Avatar
Re: Rear End Noise
If it is a posi rear end then it probably needs the oil changed and a bottle of GM 1052358 additive put in.
Old Sep 14, 2008 | 09:12 PM
Car: 86 Z28
Re: Rear End Noise
If it is posi its worn out because only one wheel spins.
Old Sep 15, 2008 | 06:56 AM
Re: Rear End Noise
That is very possible because these cars used the Auburn posi, which doesn't last long. Check for the G80 code on the RPO tag.
Old Sep 15, 2008 | 03:08 PM
Car: 86 Z28
Re: Rear End Noise
The car was originally a 2:73 open, but I don't think its that as it spins one tire very easily and runs 2k rpm at 60mph and the tcc is working, So i think it may have 3:42. I'll just have to pull the cover once i got another car to drive.
Old Sep 16, 2008 | 09:41 AM
Re: Rear End Noise
If it's a standard differential then you might have damaged it by doing one wheel burnouts. This is very hard on the differential gears and cross shaft. When you do a burnout like this you are causing the gears inside the differential to turn at very high speeds. The left axle gear is not moving, but the right axle gear is moving at twice the speed of the ring gear. The 2 pinion gears are spinning very fast around the cross shaft and generating a lot of heat. This is enough of a problem, but it gets worse because very little oil can get to these gears when the differential case is spinning. Here is an example of what happens when you do this
Old Sep 16, 2008 | 06:01 PM
Car: 86 Z28
Re: Rear End Noise
cool I should just weld it together so both spin since its crap now anyway, its made that noise since i bought the car last april. I'll just use it for now until I find a good posi differential.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
