Clutch pressure
Old Sep 14, 2008 | 02:05 AM
miner's Avatar
Car: 88 Iroc-Z
Transmission: T-56 Manual
Axle/Gears: 3.23 10 bolt
Clutch pressure
I just finished installing my clutch tonight. When I pushed the clutch pedal it is really light. It disengages the clutch fully (as far as I can tell) when you push it, but it is almost as light as the accellerator pedal. I just installed a stage 3 so it should be harder to press than stock? The car drives better than it ever has since I bought it. Is it possible that my old clutch was just so messed up that it made the pedal hard to move? My dad installed the throwout bearing while I was at work, and I didn't check it. Could that be the problem?
Old Sep 14, 2008 | 04:30 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Clutch pressure
You're worried that it works too well?
Old Sep 14, 2008 | 10:42 AM
midwest's Avatar
Re: Clutch pressure
Yes it happens all the time, sometimes they get so hard that it will cause the master to blow its seals.
Old Sep 15, 2008 | 12:50 AM
miner's Avatar
Car: 88 Iroc-Z
Re: Clutch pressure
Ok thanks, That is probably why the slave cylinder broke then.
jtwoods4
Sep 3, 2015 05:39 PM
tonys91rs
Sep 2, 2015 07:07 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
