powertrax?
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
powertrax?
I had it in a series 3 carrier 5387. Changed it to a series 2 5388 and gap is to big need to shim it togather. Makes alot of nosiey. So i need shims or thrust washers to make the gap closer. where can i buy some shims?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: powertrax?
i "rigged" one in my rear a while back, i used carrier bearing shims. I had them left over from a gear swap, not sure where to buy them
Re: powertrax?
The thrust washers in these rear ends are all .030 thick. There isn't a selection to choose from. These thrust washers are hardened so that they will wear a long time. Most shims are soft, so they are likely to be chewed up quickly. If the gap is too wide then you probably have a worn case. The case gets worn from doing one wheel burnouts and can not be repaired. You might need to find another case.
five7kid
Mar 7, 2001 09:23 AM
Pablo
Aftermarket Product Review
18
Jan 11, 2001 09:30 AM
