wc t5 Q&A
Old Jan 4, 2001 | 06:51 PM
CamaroZ_85's Avatar
wc t5 Q&A
I currently have a dying 700R4 behind my moderately built 350. I'm stuck between getting a nicely made 700R4 or converting to a WC T5. I would really like a T56 but i dont think i can come up with the cash for all the parts. i would probably come across the T5 easier too. I have a few questions on this...whats this transmission rated at? I've heard from 275-305 ft. lbs. I dont think my motor is making an incredible anount of power, but i do drive it hard...so i need to know what this trans can take. secondly, i need to know if my 700R4 prepared drive shaft will work with the T5 (length, spline count) also, i believe the first year for the WC was 88. when did the camaro's make the switch to an electric speedo? will I find a WC T5 with a mechanical speedo output? and how can i tell a WC T5 from a regular T5 if i have the 2 side by side? and last, i need to know if the clutch setup is the same for the old T5 and the WC t5. I know this is a lot but i appreciate the help i get from you guys
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
Old Jan 4, 2001 | 07:43 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I've heard 275 ft/lbs for the regular T5 and 315 ft/lbs for the WCT5.
Yes, the 700R4 and T5 use the same driveshaft.
Camaros switched to the electronic speedo in 1990, while Firebirds switched in 1987. The trans is the exact same, only the speedo is different, and the electronic speedo and cable speedo are direct swaps.
Yes the clutches are the same.
The WCT5 has a TIMKIN bearing on the front. The bottom left of the input shaft has a circle on it, that is the cluster bearing. The circumference of that circle will have writing on it that says TIMKIN. You will know its a WCT5 by that. Here's a pic of my WCT5 taken apart:
http://24.1.139.249/images/122900/DCP_0112.JPG http://24.1.139.249/images/122900/DCP_0113.JPG http://24.1.139.249/images/122900/DCP_0114.JPG
In the last pic you can see the circle on the front I am talking about.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jan 5, 2001 | 01:46 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
From Kevin: I provided links, not images, to my pics for a reason. My server doesnt need the extra bandwith of loading those pics every time. Thanks.
[This message has been edited by stingerssx (edited January 05, 2001).]
[This message has been edited by Kevin91Z (edited January 05, 2001).]
Grey Goose
Southern California Area
Jan 4, 2014 04:53 PM
89377STROKER
Nov 3, 2011 12:31 AM
Grey Goose
Dec 2, 2010 12:03 AM
