Slave Cylinder Tie Wrap
Old Sep 15, 2008 | 09:38 PM
Jonathan Dyer's Avatar
Car: '83 Berlinetta
Engine: 383 CI
Axle/Gears: 3.73, Eibachs, Tokiko Illuminas,
Hi all. I'm changing the slave cylinder and wondering what to do with the plastic tie wrap that keeps it compressed after bleeding. Do I just leave it between the piston and the clutch fork? That seems kinda wierd but I'm unsure how to install the slave without the tie on there. If I cut the tie after installation can I wrestle out what's left? The instructions that came with the slave were very clear as far as bleeeding but that's it. I guess this is meant to be obvious....
Thanks,
Jon
JSD MOD 15/09/08
Old Sep 16, 2008 | 06:12 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Slave Cylinder Tie Wrap
its meant to stay in place while you install . the first time clutch is actuated it will break . its supposed to . cap on the end of cylinder acts as a bushing with clutch arm . just install and go . good luck .
Ed1LE
Sep 30, 2018 09:14 AM
Eric-86sc
Feb 25, 2016 09:02 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
