3.42 with my 700r4 best combo?
Old Sep 14, 2008 | 08:07 PM
Morder.'s Avatar
Car: 20 M550i xDrive
Engine: LB9 305 TPI
From what I've been able to find it seems like the best gear set to go with would be 3.42 for a car with an automatic transmission and a 305/350, even if modded a bit, right?
3.73 is overkill?
My car is a daily driver (for now) and it stays on the streets. It will always be a street car and will likely never see the track but I do like to drive a bit fast.
Thats what I've gathered, is that correct? If anyone has anything else they would like to add or ask please do because I don't plan on doing this right away but it will happen.
Old Sep 14, 2008 | 08:32 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Re: 3.42 with my 700r4 best combo?
I don't know about overkill. If you ordered the 86 L69 with the 700r4 automatic transmission, the stock rear end gears were 3.42, but the 3.73 gears were an option with that setup. So GM didn't think it was overkill.
Old Sep 14, 2008 | 08:57 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Im happy with my 3.42's, doesnt seem to affect my mileage much, and takes off from a stop pretty good.
Old Sep 15, 2008 | 12:49 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
honestly, at this point I've been thinking about stepping up to 3.73's. the drop from first to second and the drop from 3rd to 4th just sucks. I feel that the step up would keep me in my powerband better.
Old Sep 15, 2008 | 02:56 AM
Morder.'s Avatar
Engine: LB9 305 TPI
Is that with a stock 305?
Old Sep 15, 2008 | 02:13 PM
Saber's Avatar
His 305 is far from stock. lol read his mods in his sig.
Old Sep 15, 2008 | 03:33 PM
Morder.'s Avatar
Engine: LB9 305 TPI
Sometimes I miss the most obvious things...
Old Sep 16, 2008 | 10:54 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Sounds pretty stock to me???? The heads and cam will change things entirely, I'd stick with 3.42's.
Old Sep 16, 2008 | 11:28 AM
jerryd87's Avatar
from what i have been reading a 700r4 with 3.23 gears is the same as a th350 with 3.92 gears(in first) so 3.42 would be prob be similar to 4.10's and 3.73 would be around 4.30s(just guesses dont feel like doing the math) ive been told first gear is like 3.10 first gear or something(if im wrong dont bash me this is just what i have been told)
Old Sep 16, 2008 | 11:37 AM
JPhillis's Avatar
Car: 1992 Camaro
Engine: 350 .030 over 298 cam 9.1 Flat tops
Transmission: T5 swap complete
Axle/Gears: 3.73 posi the 4.10s are history
I can say from experience. I just purchased a GU6 rear end to use temoprarily until I get my moser. I put it on the interstate last night and now I believe its been changed out to a 4.10. I am turning 2800 RPM @ around 70mph in OD and thats before the convertor locks up. I would STAY AWAy from 4.10's if you plan on driving it every day.
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
92projectcamaro
Sep 29, 2015 07:07 PM
JSDaddy189
Sep 26, 2015 03:50 PM
6998poncho
Sep 25, 2015 02:56 PM
