How to adjust friction point T5 clutch
Old Sep 18, 2008 | 12:04 AM
Jonathan Dyer's Avatar
Car: '83 Berlinetta
Engine: 383 CI
Axle/Gears: 3.73, Eibachs, Tokiko Illuminas,
Since replacing my clutch the friction point occurs lower in the pedal travel than before. How is this adjusted?
How much travel should I see at the fork as the clutch pedal is depressed?
Thanks,
Jon
JSD MOD 17-09-08
Old Sep 19, 2008 | 12:46 AM
92whiteta's Avatar
Car: 86 WS6 Firebird
Engine: 355
Axle/Gears: 2.73 open
Re: How to adjust friction point T5 clutch
the t5 is hydraulic. if you have air in the lines your pedal will be lower just like a brake pedal with air in the lines try bleeding the system.
camaro1185
Oct 26, 2015 06:51 AM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Gambit TA
Sep 1, 2015 07:27 PM
theshackle
Aug 31, 2015 10:47 AM
