Need T-5 swap answers:
Old Jan 6, 2001 | 03:23 PM
Tom Keliher's Avatar
I installed the bellhousing and trans so far today. I was going to install the Spohn crossmember and support the trans and then move onto the interior. However, as I jacked up the trans and crossmember to install the crossmember bolts, the shifter mounting base (no shifter installed) pushed up against the trans tunnel and I could not get the crossmember close enough to thread in all the bolts. So my question is, is the trans tunnel opening for a T-5 normally have the base of the shift plate sticking up through the tunnel?
Question number two concerns the speedo drive units. I swapped my cable drive unit for a electronic VSS unit. But the connector plug is different. The one I have was for my auto tranny. So I need a VSS plug for a manual T-5. Is the connector plug for a cable drive and a VSS drive the same? If I found a 3rd gen at the junkyard that had a T-5 in it at one time, could I pull the speedo plug knowing it fits either version speedo drive? Thanks!
FORMULA 350 TK
Southern California 3rd Generation F-Body Organization©
Old Jan 6, 2001 | 07:57 PM
Jester's Avatar
Yes the shifter base sticks through the floor, you'll need to cut a hole to clear.
The T5 actually used a few different VSS sensors, I'm not sure what changed with what year/model. Some are alot larger than others, etc. I had that problem when I did the swap...and I still don't have a speedo.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Jan 6, 2001 | 08:34 PM
Thanks for the info Jester.
Old Jan 7, 2001 | 07:00 PM
Get Blown ?'s Avatar
From http://www.jagsthatrun.com/Pages/Spe...eedometer.html
There are four types of VSS signals required by the engine computer (ECM):
1. The two-pulse (2000 pulses per mile) square wave (D.C. current or direct current) used on all TBI engines through 1992, all computer-controlled-carbureted engines, and on 1985–1989 TPI engines.
2. A four-pulse (4000 pulses per mile) sine-wave (A.C. current or alternating current) signal is required by the 1990–1993 TPI, 1992–1993 LT1 engines, and 1990–1993 Camaro 3.1/3.4 V6 engines.
hope that helps out you and Jester, good luck Tom.
1989 Camaro RS LO3 WCT5 0-60' 2.34 1/4 15.8@87mph
http://350.StreetRacing.org
WARNING: overpowering a broken posi unit can lead to abusive behavior...
midge54
Sep 2, 2015 06:27 PM
Cacike
Aug 27, 2015 05:10 PM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
