A Juvinile Question...
Old Jan 7, 2001 | 03:12 PM
Bort62's Avatar
... From a Sorta Juvinile Guy.
When You Do a brakestand ( we all know what that is ) What Damage aside From Tire wear are You causeing, and Is there anything BAD about it ? or just normally acclerated wear associated with raceing anyways.
In other words, Is there anything just waiting To break when You do this ?
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Livin' the Stereotype
Old Jan 7, 2001 | 04:50 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Extensive "PowerBraking" or "Brakestanding" can cause the torque converter to overheat, but other than that, nothing that wouldn't normally brake during a regular tire-spin.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Jan 7, 2001 | 05:27 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
it would be best too use a line locker,set it up so you can use it from inside the car.that way when the cops show up you can use your rear brakes as you get chased away!
I used to do some nonsense brake stands with my trans am,the rear disc brakes were toasted,the 700r4 shifts a little softer,no trouble from the rearend,not to sure about the engine.overall the car got pretty badly beaten. it would have been better to use a line locker,but it was still fun.
Old Jan 7, 2001 | 07:06 PM
Bort62's Avatar
Well Ive heard its bad to Do it on Disc brakes, but On My drums I dont have that problem
Yeah a Line Lock would Be nice, but I dont think that My Lg4 Powerd SC is quite in need Of a LIne Lock
Thanks For the answers tho, Just something I wonderd about ( not like I ever Do anything as juvinile as that.. )
Old Jan 7, 2001 | 07:43 PM
SGT SWEETPANTS's Avatar
Definately tires and brakes. Also, I busted a motor mount in my '70 Impala doing a brake stand. Other than that, not a whole lot (as if that isn't enough. Have fun and don't get caught.
'86 IROC-Z, 305 LG-4, T-5, T-Tops, 50k Original Miles, K&N Air Filter, Jet chip, KYB Shocks/Struts, Centerforce Dual Friction, B&M Ripper Shifter
Old Jan 7, 2001 | 11:56 PM
Bort62's Avatar
Dont get caught ? Hmm how does **The campus police saw the smoke off the top of the parking garage and thought there was a car on fire** Sound For getting caught ? :_)
Old Jan 8, 2001 | 01:50 AM
XxMoLexX's Avatar
I have a 91 RS 3.1. Yea i know .. its a baby ... yada yada yada.
Well anyways i used to beat the crap out of it and powerbrake with the best of em. Other than going thru 4 rear tires. in 2 months They were ****ty goodyears but not the point.
I blew out my rear wheel cylinders and locked up a front brakeline. On top of that ... i went thru 3 tranny mounts. The tranny mounts i replaced it with i guess jus sucked. But still weakened the crap out of em.
Hey it was fun to do better burn outs then the idiots with the 5.0 stangs but cost a damn pretty penny since i had to get the wheel cylinders done at a mechanic cus i was out at college when i found out.
BTW where can i get a good tranny mount that wont explode at the slightest bit of torque. Im guessing polyurethane but jus wanted to know if there was something i was missing.
Thanks.
My opinion have fun with the burn outs and stuff if u got some new tires and other stuff lined up and jus wanna beat it up.
Old Jan 8, 2001 | 01:36 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep, the ES poly mount is the one... $27 thru Summit. Prothane also makes one now, and it's cheaper; Summit Racing has that one too.
I have the Energy Suspension one, after busting two stock ones with my 2.8.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jan 8, 2001 | 11:03 PM
Bort62's Avatar
well, I dont really Do this that often at all, actually Havent Done it at all For a while, but I was just wondering, I dont like sitting there doing something that I "wonder" what negative effects it is having, I like to know exactly the pro's and con's of what Im doing.
thnx for the info everyone
Old Jan 9, 2001 | 08:30 PM
Engine: 2.2
autozone lifetime warranty t-mount $9.99,so hard it has to be urathane.
Galaxie500XL
Oct 1, 2015 01:05 PM
happyhapka
Aug 15, 2015 04:42 PM
ebmiller88
Jan 28, 2002 09:51 AM
KlayBuRn
Car Audio
Aug 30, 2001 12:52 AM
Lotsokids
Carburetors
May 28, 2001 08:42 PM
