Non lock up converter in a 700R4! Modifications?
Old Sep 21, 2008 | 05:05 PM
Kevin Baden's Avatar
I have a 4500rpm non lock up installed in a 1988 camaro! It is behind a 355 with aprox 425HP. If I run the shifter in #3 position and not in the #3 lockup position, will I have to modify the trans to prevent oil flow to the converter for the lock up? In short, will this work like a 350Th in this shifter possition? Will this operate with out damage to the trans or the converter?
Let me know! Thank you!
Kevin Baden
Old Sep 22, 2008 | 01:06 PM
Re: Non lock up converter in a 700R4! Modifications?
I have contacted Coan Transmissions out of Kokomo Ind! I have a convertion kit coming! I can't beleave no one on this forum had an answer for me!
Old Sep 22, 2008 | 06:51 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
I believe you have to do something with the lockup valve in the front pump, there may be posts online. Also IIRC remove the check ball in the input shaft. Aside from that make sure you have a good secondary cooler if its street driven. That thing is going to generate serious heat!
Old Sep 22, 2008 | 07:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A search would have got you your answer.
https://www.thirdgen.org/forums/tran...ght=lockup+non
1992 Trans Am
May 10, 2023 07:19 PM
C409
Sep 1, 2015 03:42 PM
someone972
Aug 30, 2015 12:52 AM
Eric-86sc
Aug 24, 2015 09:01 PM
Jake_92RS
Aug 17, 2015 09:42 AM
