Is My Transmission Busted? Please Help
Car: 1988 Firebird Formula WS6
Engine: LO3 305 tbi
Transmission: 700 R4
Axle/Gears: 3gen housing zexel torsen posi 3.42
Ok the other nite being a hardass, i accelerated hard off a traffic light, i heard a big pop and my transmission seems to be shifting late into second and try and put it in second manualy and its as if i put it in nuetral
Car: 1984 camaro sport
Engine: 2.8 v6
Axle/Gears: 10 bolt posi rear
Re: Is My Transmission Busted? Please Help
sounds like linkage bent maybe also from the pop does it do it off of a gentle acceleration ?
i had similiar issue turned outto beleiveit or not to be a 8.00 dollar transmission mount a whole 10 minutes work the shop said motor mounts but linkage and shifting seemed off. transmission was turning and moving around kinking the linkage
Last edited by dartravens; Sep 26, 2008 at 04:50 PM. Reason: Automerged Doublepost
Engine: LO3 305 tbi
Robert R.
entry lvl tech apprentice
Engine: 2.8 v6
if ya have ramps run the front on them then put a jack under your transmission pan put a peice of wood on it so not to damage the pan and slowly lift the transmision you should se the one crossmember accross the tranny i believe its 2 bolts on each side + one on the center take that off and see if the mount comes apart in two peices after time the rubber on the mount seperates from the metal and it has to be replaced the linkage should be on the driver side of the transmision put blocks at the tire and the key in and have some one go through the gears with the car off see if ya see any thing binding
also check joints on either side of drive line for broken bolts or brackets
Last edited by dartravens; Sep 27, 2008 at 06:33 PM. Reason: Automerged Doublepost
Engine: 2.8 v6
check napaonline they should be able to show pic of mount on your car
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
