700r4 question??
Old Sep 26, 2008 | 09:42 AM
kosbo77's Avatar
Car: 1990 trans am gta
Engine: 5.7 ltr 350 stock
700r4 question??
When normal driving, my tranny shifts from 1st to 2nd extremely hard and will shift into 3rd kinda hard also. If I drive with WOT, then it shifts very smooth. Surely this isn't normal, is it?
Old Sep 26, 2008 | 09:56 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: 700r4 question??
what rpm does it shift at when you are justdriving around? when is that last time you checked to see if your tv cable was adjusted right?
Old Sep 26, 2008 | 10:16 AM
kosbo77's Avatar
It shifts at about 3200 rpms. The cable has been set correctly following instructions from this site. Just to let you know, it doesn't always do this but more often than not. Someone told me it was probable a stuck valve. If this is the case and I get a Transgo Shift Kit, will I have to manualy shift from then on? I know, I'm not very bright.
Old Sep 27, 2008 | 10:13 AM
Pro Built Automatics's Avatar
The TransGo Performance Shift kit that I use and carry will make the part throttle shifts smooth and the WOT shifts firm. Let me know? Dana
Old Sep 27, 2008 | 12:38 PM
yeah most shift kits will be like this. smooth shifting when cruising then hard quick shifts when wot. and no, if you install a shift kit it will still shift by itself.
Old Sep 28, 2008 | 03:10 AM
Unless you setup the kit for "full manual", then they are always "fully automatic".
camaro11j
Sep 19, 2018 08:49 AM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 11, 2015 10:22 AM
Leggman1
Aug 6, 2015 04:15 AM
