Can I use the same driveshaft with a 350 tranny?
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I'm thinking of putting a th350 in the place of my 700r4. What I need to know is if I get the changeover thing for the torque arm will the driveshaft need to be a different length? I'm guessing that a short tailshaft 350 is the same length as the 700.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The 700R4 is the same length as a long 9" tailshaft TH350 (within a 1/4"). The short 6" TH350 needs a driveshaft from an 82/83 with a 200C tranny.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block almost ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Eric-86sc
Aug 24, 2015 09:01 PM
