Flywheel Resurfacing Tolerance
Old Sep 24, 2008 | 10:55 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I have personally resurfaced my flywheel once and am unsure of any other times. What is the spec/how do I go about checking that so I know whether I can re-use and resurface this flywheel again?
Also, there was a thin piece of round metal (I'm thinking a spacer when the flywheel was resurfaced before myself doing it???) and last time I installed the flywheel and clutch I placed that metal piece behind the flywheel assuming it was to space it out and keep it within range of the clutch...was that correct?
Old Sep 25, 2008 | 01:30 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Flywheel Resurfacing Tolerance
I doubt any spacers are needed... I've never seen one.
What flywheel is this? Aftermarket, might be able to find a spec from the maker. Otherwise I doubt you'll have a problem. Just go get it machined flat. Not like brakes where you run out of meat, it'd take a while for that to happen with this.
Old Sep 25, 2008 | 10:08 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Stock flywheel to my knowledge. The little spacer was on the old 305 so I carried it along to this rebuild. Guess we'll see what happens!
Elephantismo
Feb 13, 2019 12:51 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
