Auto ->T5 swap: Engine wont crank?
Old Sep 26, 2008 | 01:33 PM
SpeedJunkie's Avatar
Car: 88 IROC
So I have everything back together, new starter, clutch, and all the jazz. Now I have the 4 prong wire from the 700R4 hanging by the new tranny. I believe i have to splice two of these wires into the reverse switch and just hide away the other two.
I installed 3rd gen pedals and did not hook any cruise control or remove any auto stuff from the sterring column. Do I need to hook up a nuetral safety switch to the clutch pedal to even start it? or do i have some other problem.
Old Sep 26, 2008 | 03:29 PM
Car: 88 IROC
Re: Auto ->T5 swap: Engine wont crank?
Ok so I connected the old auto nuetral safety switch and put it in the park position. It still wont crank. im leaning towards some other problem maybe.
I do not need a clutch nuetral saftey switch to start the car correct? just need to make sure its in nuetral?
Old Sep 26, 2008 | 04:31 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the auto had the neutral safety switch on the selector switch on the shifter itself. You have to hook it back up somehow to make it work, the trans should have a switch in it, and there should be one on the pedals. That way the clutch HAS to be in and the trans HAS to be in N for the car to crank. I suppose if you too the wires that used to go the the auto shifter switch, the large purple and yellow wire, and tied them together it would work, but its not a good idea
that will take care of the switch, is the starter wired right? did you mess with anything else?
Old Sep 26, 2008 | 09:17 PM
Car: 88 IROC
Ok i connected the auto nuetral one back in, but i did not hook up the 2 wire switch for the reverse lights. now if I do not have a clutch switch where I have to push down the pedal to start with the car in nuetral it should start anyway correct? I mean basicly the car thinks its still an auto in park. If i have all the auto stuff hooked up and no "new electronic" switches to splice or add into the car it should still crank?
Old Sep 26, 2008 | 09:35 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Yes, it should crank. I wired the purple and yellow wires together at the neutral safety switch and mine will crank whenever. I do have the clutch switch, but haven't bothered to put it in.
Old Sep 27, 2008 | 11:41 AM
Car: 88 IROC
Alright I did get it to start. I hooked up the old auto shifter nuetral safety switch and also I forgot that i had cut the yellow ignition line when I removed the gm goodwrench alram system.
All is well, thanks!
1992Z28!
Nov 19, 2015 07:33 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
88rscamar0
Sep 23, 2015 09:08 PM
BBSDesigns
Sep 22, 2015 03:08 PM
