97-down vs 98-up T56 questions
Old Jan 10, 2001 | 10:39 PM
L98ina25thZ28's Avatar
What are the differences in the ls1 and lt1 t56 trannies. Has anyone cunverted an ls1 model to work with a small block? I have already done the conversion but mine pops out of reverse. It seems there are more 98 & ups available than 97 & down. Is it as simple as switching the bell housing & clutch or is the input shaft different? Can the input shafs interchangeable?
'92 Z28
5.7 TPI
T-56 six speed
Pro 5.0 shifter
3.73's
SLP 1-3/4" Headers
SLP Cat-Back
52mm TB
Extrude Honed Intake/Ported plenum
Hypertech Prom
Old Jan 10, 2001 | 10:41 PM
Sorry about the last sentence above, I meant to say are the different model input shafts interchangeable?
Old Jan 11, 2001 | 09:51 AM
Mark W. Winning's Avatar
I know the bellhousings are different, but I also think the clutch hydrolics are different. I was looking at an LS1 six speed setup for my 3rd gen (already have a t-56 installed) and was told I would have to change the slave cylinders again.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old Jan 15, 2001 | 02:13 PM
88SS6SPEED's Avatar
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
I would say it is possible to change the INPUTSHAFT out, since it is LONGER than the 97-Below. I don't think that TREMEC TOTALLY REDESIGNED the tranny just for the LS-1 change, they just installed the new inputshaft, front cover, bellhousing, and hydraulics. You would need to get a 93-97 front and inputshaft for it to work in the conventional fashion, since the 98-up front cover DOESN'T have provisions for the CLUTCH FORK POST.
88 Monte SS 355 TPI/LT-4 HOT CAM/AFR Hydra-rev/ T-56 6-Speed
Old Jan 18, 2001 | 08:13 PM
AustinT's Avatar
THats good to know the Lsl tranny has a longer input shaft. Does anybody know just how long it is. The aftermarket T56 also has a longer inputshaft because of the 1/2 inch plate that adapts it to the stock bellhousing. This means maybe we could build our own adaptor plate and use an ls1 tranny or at least the ls1 inputshaft.
Old Jan 19, 2001 | 12:08 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I too have been wondering this. My suspicion is that the LS1 is very similar to the aftermarket t56. The input shaft on my aftermarket is a lot longer than the production one. Does anyone have the tag number from a LS1 six speed? I wouldnt mind calling Tremec and trying to find out the differences, but I need the tag number from an Ls1. I think that if you get an ls1 six and use the t-5 bell with a custom adapter plate it would all work. But I am not sure about the tailshaft. Too bad it is such a pain calling Tremec and talking to the idiot tech guy. Last time I called he couldnt even answer my questions!
If the women don't find you handsome they should at least find you handy
88 GTA Notchback with 91 gfx and ROH Snypers
Aftermarket T-56 (pain in the A$S but worth it)
Lots of things to do still
[This message has been edited by scooter (edited January 19, 2001).]
Old Jan 19, 2001 | 12:09 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Oh also what spline count is th LS1 tranny? That makes a difference in how much of a pain it is. If it is the same (26 I think?) it would make the whole job easier.
Old Jan 19, 2001 | 12:41 PM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
OK here is all the data on the different T56 transmissions:
Input shaft length: ['93-'97: 9.188 in] ['98-up: 10.75 in] [aftermarket T56: 6.66 in]
Input shaft spline count: all have 26 splines
Bellhousing depth: ['93-'97: 4.882 in] ['98-up: 5.531 in] [aftermarket T56: 6.290 in]
These numbers are straight from the june 2000 issue of Car Craft
1991 Z28 - 350 TPI, T56, McLeod street clutch, ported plenum & runners, AFPR, Holley Annihilator ignition box and wires, Hooker shorty headers w/o AIR, no cats, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Steve Spohn adjustable torque arm and T56 crossmember
Old Jan 19, 2001 | 02:01 PM
AustinT's Avatar
I just emailed I guy who has a ls1 t56 I the said from butting the ruler up against the tranny to the end of the inputshaft was 7.25 inches. Any body with a aftermarket T56 Know the measurment on your input shaft?
Old Jan 20, 2001 | 12:40 AM
AustinT's Avatar
A guy on ebay is selling a ls1 tranny right now here are the numbers from it
12552099 K1982
13 86 017 28328
19irocz85
Aug 26, 2015 07:54 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
