2.8 Stroker - flywheel change?
Old Sep 29, 2008 | 09:43 PM
GTA50's Avatar
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
Sp on my 1989 Firebird, I've rebuilt the 2.8 into a 3.1. I have a 5-speed WC transmission. The question is since the 2.8 is externally balanced and the 3.1 is internally balanced, do I need to change my flywheel?
Old Sep 30, 2008 | 07:00 AM
big gear head's Avatar
Re: 2.8 Stroker - flywheel change?
Are you sure that your 2.8 was externally ballanced? The early 2.8 was externally ballanced, but the later ones were internally ballanced. Check your flywheel for the counter weight. If it has one then you need another flywheel. If it doesn't have one then you can use it. I swapped my early 2.8 for a 3.4 and used the flywheel from a 2.0 or a 2.2 4 cylinder.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
19irocz85
Aug 31, 2015 10:31 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
TEEZER TA
Aug 30, 2015 06:35 PM
Trickskier
Aug 29, 2015 01:12 PM
