GTA differential blowing fluid ?
Old Jan 22, 2001 | 04:21 PM
79 WS6's Avatar
Never experienced this before. My 87 GTA is shooting fluid from the relief/pressure valve. It is the plastic covered nozzel on the far left top of the rearend.
Any thoughts as to what would cause this?
Thanks,
Jim
Old Jan 22, 2001 | 06:27 PM
ede's Avatar
ede
excessive heat build up in the fluid. i'd pull the cover and cheack the bearings on the carrier, the pinion, and the axles as well as any other parts for wear and tear. be a good time to change the fluid and add posi additive if you have posi any way.
ICON Motorsports
1st & 3rd
Old Jan 22, 2001 | 06:38 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Water in the fluid, combined with heat, will do that every time. Speaking strictly from experience as a boat person.
It sounds like you need to pull the cover, real soon.
ICON Motorsports
Old Jan 22, 2001 | 08:36 PM
79 WS6's Avatar
I plan to pull the cover this week. She uses GL-5 (80W-90) and the additive...correct?
Thanks for the info.
Old Jan 22, 2001 | 09:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
75W90 is the more typical weight these days.
If you fill it with AMSOIL Series 2000 75W90, you won't have to buy the additive. And, you'll start enjoying the benefits of synthetic lubricants.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, TBD heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
machinist21
Sep 5, 2015 03:03 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
90formulaVortec
Sep 3, 2015 09:26 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
