How do you hook up back up lights?
Old Jan 17, 2001 | 05:33 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
I am putting in a t5 on place of my 700r4? OR atleast trying too. Ok What wires do I need to hook up to my trans to have backup lights. It is going in a 1984 trans am. Do I need to get a new plug on the trans.or what? Thanks 4 ur help again. Kevin
Old Jan 18, 2001 | 11:19 AM
kjgroen's Avatar
Car: Trans Am
Engine: L69
ttt
Old Jan 20, 2001 | 12:47 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
Anyone
Old Jan 20, 2001 | 01:34 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
on my trans there was a reverse light sensor that had a 2 prong plug. I wasnt sure which wire it was either so i tested them all until one of the wires worked! test em!
89 Firebird (AKA "Money")
2.8 V6 w/ t5 tranny (383 tpi t56 12/01)
Flowmaster 80 series, 3" Intermediate, SS Tips, Random Tech Cat, Msd Coil, MSD 6a, Accel 8.8 wires, Cold Air Intake w/ K&N, Lakewood LCA's, Brushed aluminum Hood pins ETC...
Next:
Spohn Torque Arm, Lakewood Panhard bar, BMR Fabrication Sub Frame connectors...
My Site:
www.geocities.com/firebird89white
" I'd rather run last in a full out race, than to NOT run at all ".
Old Jan 20, 2001 | 02:21 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
so I just need to find the wires from the auto backup lights and hook them to the prong on the t5? That sounds easy enough. Thanks Kevin
Old Jan 20, 2001 | 04:39 PM
yea basically if u look on the backup sensor there is a two prong connector which u need to get. I saw one at pepboys for 3 bucks then splice the wires into that.
Next:
My Site:
[This message has been edited by Graeme'sFirebird (edited January 20, 2001).]
Old Jan 21, 2001 | 01:56 AM
cfabe's Avatar
The connector on the t-5 that is for the backup lights is the one near the center of the tranny, not the one on the tailhousing. If you have the undercar harness from the t-5, the wires for the backup plug should be blue and green. Also there should be yellow and pink, those are for the VSS. In the car, the wires you want to splice into are blue and green, and can be found in the connector that plugged into the auto tranny shifter switch. This switch controlled the neutral/park start interlock, as well as the backup lights. There are also two other small guage wires in the connector that I'm not sure what they do.
Hope this helps, just did the VSS and backup wiring for my tranny/engine swap tonight.
82 T/A 305/TH350; soon to be 350/T-5
Old Jan 22, 2001 | 10:17 PM
84FTA's Avatar
I wonder what those wires are for....so the ECM knows when it's in P or N??? I believe they followed the same pattern as the thick P-N wires when I took the switch apart. I creatively moddified my old TCC plug into the prong for the reverse lights for the hardtop....that reminds me I still need to put reverse lights on the T-top car.
1984 WS6 Trans Am Hartop
Former L69 Car under restoration
1984 WS6 Trans Am T-tops
4-bolt main 350, headers, Holley 650, T-5, dual elec. fans and 3.23's.
Daily driver and restoration
13.98 @ 101
justin57
Aug 20, 2015 07:05 PM
tnrednneck
Aug 13, 2015 08:57 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
Omega
Aug 10, 2015 12:46 PM
