Bad Buck
Old Oct 1, 2008 | 10:30 PM
orangemonster's Avatar
Car: 1986 IROC 305 TPI
Engine: 1989 RS
Transmission: 5 speed
Axle/Gears: 3.08
Bad Buck
The 700r4 Automatic on my 1986 Iroc 305 tpi is ridiculous. When first put into gear drive or reverse, at a 750 rpm idle it bucks or kicks pretty hard. It lurches forward a bit and almost stalls the motor out. Also a few times, not all the time, when driving normal the car would rev up to 2500 and shift hard into the next gear. Car only has 40,000 miles on it. Any help would greatly appreciated and thankyou.
Old Oct 4, 2008 | 12:03 AM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: Bad Buck
is there any delay when u put it from park to drive or park to reverse? if so chances are the transmissions clutches are a bit worn.
not to mention if the motor mounts are bad, it will add to the bucking, also could be a transmission mount or a torque arm bushing.
69GTOby
Apr 18, 2016 02:34 PM
jerflash
Sep 24, 2015 03:11 PM
jerflash
Sep 23, 2015 09:21 AM
gta892000
Sep 16, 2015 12:40 AM
3rdgenkindagal
Sep 13, 2015 02:02 PM
