Drive shaft u-joints
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Hi guys,
A few days ago I was under my car and decided to twist the drive shaft by hand to see if there is any play. It turned by hand a good bit with the rear wheels on the ground. Is this normal? There was now play trying to move it up and down, or left and right. But if I tried to turn it, it turned probably 1/8 to 1/4 of a turn. My car has a 3.42 posi rear end.
Thanks alot for your help.
Car: 82 camaro sc
Engine: 355 SBC
Axle/Gears: ford 8.8 3.73
Re: Drive shaft u-joints
is it an auto or manual. if im not mistaken then manuals will tend to have more (play) but if you getting 1/4 out of it than i would say that your pinion in th reareng needs to be shimmed because there is too much backlash in the gears.
Engine: 305TPI
The car is a 5 speed manual. How much are you supposed to be able to turn it? Maybe it is a bit less than a 1/4 of a turn, but it is a noticeable amount.
1992rs/ss
16
Jan 28, 2016 09:58 PM
Ozz1967
Aug 16, 2015 10:23 PM
