How can I tell what year 700-R4 I have?
Just as the subject implies....
Owner of a 1989 IROC Camaro, a.k.a. "The Babe Magnet". Painted a cheap metallic blue that chips off all too easily and covers over the IROC decals on the doors, also has non-leaking T-tops, ps, pw, power rear hatch, working A/C. Mods: SLP intake runners, gutted MAF sensor, adjustable fuel pressure regulator, modified air spoil, 3.2? posi rear end.
Broken stuff: rear spoiler brake light, driver side lock, power antenna, tilt steering, rear end bushings, cracked passanger side ground effect, washer fluid tab, leaking exhaust and a rotted through muffler that sparks when the car bottoms out while driving like any 17 year old does.
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
write down the most official # on it and go to the dealer to have them look it up for you
theres a more scientific approach, but i cant think of it right now
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 226/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
13.24@104
13.24@104
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
On the passenger side of the tranny case just above the pan, toward the forward edge (under teh cooling lines) there will be a series of numbers stamped in a flat. On my truck, the number reads 7TJM013B. The first digit is the year, in this case a 1987 model.
KevinP92Z
92 Z28 383 SLP cam,SLP headers,SLP 2ontheLeft,Trick Flow TW heads & pistons,Edelbrock base,Accel SuperRam,52mmTB,Scat Crank & forged ConnRods,MSD 6AL,SLP convertor,Baer 13/12" Track,Moser axles,Hotchkis,Genuine GM 3.42s,SLP HD Torsen,17x9" chrome SS rims
96T/A w/SLP Ram Air,SLP 2ontheLeft, Bilsteins, Baer, Hotchkis, Genuine GM, Torsen
76 4X4 Blazer 400TPI project
KevinP92Z
colton_carlson
Mar 8, 2019 12:21 PM
