a quick 4L60E ?
Old Jan 12, 2001 | 10:54 PM
Stonewall3's Avatar
a quick 4L60E ?
If i was to use the 4L60E tranny out of a 4th gen camaro i know i have to use the computer for it. My question lies with the shifting assembly. How exactly does the transmision hook up to the 3rd gen shifter. And also i read that u can use the megashifter wit the 4L60E but u need some sort of a controler to send the signals to the cpu. Any help greatly appreciated.
Stonewall,
88 TBI camaro, Edelbrock TES, Flomaster muffler, High flo cat,K&N open air element, Hypertech Thermomaster, 16" iroc wheels, MSD plug wires, Edelbrock strut tower brace, Bilstein shocks and struts, Hotchkis springs, and many more....
350ci 400hp motor in the works.
Old Jan 13, 2001 | 07:31 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
If your just looking for a quick replacement tranny to get you out of a bind, don't do it. I really don't see how the shifter would be a problem, its the electrics that will give you the biggest problem.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Jan 13, 2001 | 02:54 PM
Stonewall3's Avatar
Thanks for the response. The reason im asking about this is because im contemplating a lt1 swap wit the 4L60E. And i just wanted to know what the finishing touches would be on the instalation of this transmision.
Stonewall,
Old Jan 26, 2001 | 06:25 AM
FBODY-ADDICT's Avatar
As far as I know in '93, the first year of the fourth gen, GM used the 4l60 non electronic transmission(guys correct me if I'm wrong) if thats the case stick to that one. I'm also considering popping in a 4l60 to go along with a 3.4L from a '93 camaro in my thirdgen firechicken.
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
