T56 PPM
Old Jan 25, 2001 | 05:10 PM
N.W. WS6's Avatar
T56 PPM
Hey Fellaz,I just ordered a Dakota Digital speedo interface so I can recalibrate my speedo after a T56 swap.What I need to know is the pluse per mile(ppm)that my 94 borg warner T56 tranny is sending out so I can hook it to the proper connector on the Dakota Digital speedo interface unit.............Thanks
Old Jan 25, 2001 | 05:59 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Check out www.jagsthatrun.com They have info on their website about this.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jan 25, 2001 | 06:12 PM
N.W. WS6's Avatar
Hey,I checked that jtr article but it still doesnt give the output coming from the tranny itself.What it does give is the 17 tooth per driveshaft revolution.Now if I only can convert that into pulses per mile (ppm).any ideas?....thanks
Old Jan 25, 2001 | 07:31 PM
Birmass's Avatar
Hey, I did a T56 conversion and got the cyberdyne speedo box. There must be something wrong with mine. First of all, the range of the box is just a hair outside of where I need it to be for my speedometer to be right. So the speedo either shows 10 above what I am actually doing or nothing at all. Even if I don't touch it it will change calibration. Sorry I don't have an answer to your question, but I would think you could do it by trial and error. For some reason I remember the T56 being extremely high in PPM. If you get it to work dependably could you please report back?? I'd like to order one if it'll work better than what I have.
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
SIX-speed
open 3.73's
2 1/4 stock catback
I love pissing those LS1's off
My Formula
Old Jan 27, 2001 | 04:53 AM
JIMS406RS's Avatar
I have the cyberdyne piece and it works flawlessly
check your connections or maybe you have a defective box
91 RS
HOTCHKISS LCA'S PANHARD AND SPRINGS.
ALL URETHANE BUSHED
SUSPENSION TECHNIQUES SWAYBARS
SUBFRAME CONNECTORS
SPOHN TORQUE ARM
KYB'S
WHITE FACE GAUGES
COWL HOOD
92 Z28 SPOILER, GRILL AND FOG LAMPS
ADMIRAL BLUE
T-56
3.73'S L/S
SPOHN LCA BRACKETS
406 DFI
SUPER RAM
AFR 190
COMP CUSTOM CAM....
Old Jan 27, 2001 | 10:29 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
It's 4000 per mi.
Chronologically challenged. But still kicking!
92 CAMARO RS
305 TBI 5/spd (now TPI)
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+
Old Jan 28, 2001 | 12:31 AM
Birmass's Avatar
4000 - Are you sure?? I thought the 700r4 put out 4000ppm. The T56 is much higher than that.
88 firebird formula
350 Vortec TBI
Edelbrock headers
SIX-speed
open 3.73's
2 1/4 stock catback
My Formula
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
