Torque Arm Question.
Old Jan 28, 2001 | 08:10 AM
Fiero_Freak's Avatar
Car: 2014 Camaro 2SS/1LE
Engine: 6.2L LS3
Transmission: Tremec TR6060
Axle/Gears: 3.91
I'm replacing a rear end in my 87 TA. The new rear end not only has a torque arm that the lips curl the opposite way it also is completely solid. My current torque arm has open sections in it. I suppose this is to reduce weight? The solid one is from a later model Camaro. Is there a difference. Is there difference in flex? BTW the solid torque are came out of a v-6...?? so I'm not sure what to think. Any input?
Old Jan 28, 2001 | 10:46 AM
OLDYELLR's Avatar
Car: '85 IROC
The only difference is the bushing assembly at the front. You will need to change that. I don't know about which one is newer, or the reason for the difference, but my '83 T5 had the solid torque arm with the lips facing the driveshaft and my '85 has the slotted one with the lips facing away.
1985 Yellow IROC-Z 5.0 HO, T-5 3.73 Posi, 4 wheel disks
PFCM pads, GTA wheels, Koni yellows, B&M Ripper, Dynomax
Old Jan 28, 2001 | 03:13 PM
Engine: 6.2L LS3
Axle/Gears: 3.91
That's the thing. The original 87 had the slotted one and the 1 rear had the solid one??? So it's not a year related thing since your 83 was solid and 85 slotted. I'm not as worried about the bushing...just want the best part.
Old Oct 31, 2005 | 12:29 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
Back from the dead....
I have both laying around, the solid and the one with holes in it. They are the same thickness, so the solid one is probably better, but does anyone have any more details on this? Why didnt the WS6 cars have these?
Old Oct 31, 2005 | 06:30 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
wow, back from the dead alright...
I would imagine the solid one being quite a bit stronger at the cost of the added weight.
Nervous2
Oct 8, 2015 10:53 PM
luvofjah
Sep 26, 2015 08:28 PM
89newfun
Sep 16, 2015 09:28 AM
Ragtop Man
Sep 12, 2015 12:23 AM
