Transmission problems
Old Oct 6, 2008 | 10:50 PM
rmhspeed's Avatar
I have a 1985 camaro. The transmission just went out and I have a choice between a turbo 350 or rebuild my 700R4. This car is an everyday driver and I'm only 17 so money is a slight issue. Which one should I go with?
Any help is appreciated.
Old Oct 6, 2008 | 10:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Transmission problems
There's a lot less hassle involved in rebuilding the 700R4.
Old Oct 7, 2008 | 07:50 PM
Pro Built Automatics's Avatar
With the 700R4 you will save gas, which in the long run is the way to go. The TH350 is a little cheaper to build, but you will have adapt it to the vehicle which can get expensive, and you will lose overdrive, which will cost you more in gas and the added noise, which can be hard on your nerves. If you are going to do this yourself, then I have everything that is needed to build these. Dana
jhawkeye
May 25, 2022 06:33 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Cleotiz
Jan 6, 2018 08:56 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
