where can i get heavier weights for my governor in my 700R4?
Old Jan 27, 2001 | 07:48 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Ive heard that if i have a soft 1-2 shift nd no 2-3 WOT upshift to switch to heavier weights on the governer. under part throttle, 1-2 is pretty crisp, but WOT lags pretty bad. I have a shift kit in it. Where can i get these weights? is there a part # i can get??
1989 GTA, L98/auto, t-tops, Black w/ grey int.
Ran a 14.85 @ 93.4 mph w/ 305 exhaust (2 little crossflow mufflers), descreened MAF, TB coolant bypass, and casting wall ground down behind throttle plates.
Old Jan 28, 2001 | 08:39 AM
Nitro Don's Avatar
B&M sells a governor recalibration kit.It comes with springs and weights.
The govenor controls the shift point at a
specific RPM.The B&M kit would basicly let you "tune" your shift points.
I dont think that the govenor is your problem.
I would start by reseting you TV cable.I bet
the TV cable is your problem.
Nitro Don
1990 Trans Am WS6
305TPI 700R4
ENGINE:
150hp NOS kit
March underdrive pulleys
Edelbrock headers(JetHot)
Mac off-road pipe
Flowmaster exaust
Jacobs ultra coil
K&N filter
Fulley ported base,
runners,& plenum
Crane AFPR
Hypertech airfoil
Crane 1.6 rockers
210/220 .533/.544 Cam
W/P Torquer heads
Edelbrock TPI Base
Edelbrock TI Runners
Edelbrock 52mm T.B.
TRANSMISSION:
Richmond 3.73's
Auburn posi
B&M Mega shifter
B&M Transpak
Vette servo
B&M 2400 converter
TCI Trans Rebuild
Nitto Drag radials
FUTURE MODS:
The 700R4 is DEAD!!
Neeed to rebuild AGAIN!!
BEST RUN:
12.48 @ 109.23 MPH
(with stock heads,cam,intake,and crappy Pep Boy's tires)
Old Jan 28, 2001 | 10:51 AM
84L69TA's Avatar
Car: 4 Mopars total
i tried that. ive had my TV cable set every possible way. it dosent change anything. im stumped
Old Jan 29, 2001 | 10:13 PM
Black89GTA's Avatar
I don't beleive you need hevier weights for your goveror. I had the same problem you have, same car, engine, everything. Are you sure the tranny thats in it came from a GTA? If it didn't it may have incorrectly calibrated weights. Heavier weights will make the governor spin out faster, thus making the shifts too soon, or in your case not shift down correctly. Go get a governor from GM and make sure you can return it if your car already has the same one they gave you. It's really easy to change these, probably about 10 mins. Just look on the drivers side of the tranny there will be a circular cover lookin thing. Simply pry that out with a screwdriver and pull out the Governor, slide the other in, and calibrate your TV cable to suit your needs and see if it helps.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
