700R4 Overdrive issues
Old Oct 9, 2008 | 09:06 AM
Todd Chastain's Avatar
Car: 87 iroc z28
Engine: 5.7 TPI
My 87 Iroc-Z keeps shifting back and forth from drive to overdrive while driving at low speed, about 20-40 mph. It dosen't do it at faster speeds. If I shift it manually through the gears it doesn't do it. Does anyone have an idea of what might be causing this.
Old Oct 9, 2008 | 09:35 AM
83TransAmRECARO's Avatar
Car: 83 Pontiac Trans Am Recaro
Engine: Crossfire 350
Axle/Gears: 4.10 posi
Re: 700R4 Overdrive issues
I've got the same problem with my 83... in fact every gm I've had with the 700R4 has done that...
let me know what you find out...
its more pronounced in my 83 with the shift kit then the others were...
Old Oct 9, 2008 | 10:18 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
My first guess would be that your TV cable needs adjustment / replacement.
http://wiki.answers.com/Q/What_is_th...evy_Camaro_Z28
Probably explains why it works when you manually shift it... I got that problem with my cavalier... It's annoying as hell i feel ur pain lol..
Later
Old Oct 9, 2008 | 11:41 AM
Car: 87 iroc z28
Engine: 5.7 TPI
What does it look like? How do you go about adjusting it, and how much?
Old Oct 9, 2008 | 11:57 AM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Really only one way to reset the TV cable. Not intended to be 'adjustable'. But it does sound like a low line pressure rise, so readjust it as instructed and try it out.
But that issue is an inherent problem and a shift correction kit from Superior or ProBuilt should fix the issue permanently
Prodigious
Nov 7, 2020 09:23 AM
Prodigious
Oct 4, 2015 11:20 PM
Americanmouse
Sep 7, 2015 12:10 PM
greenyone
Sep 2, 2015 03:39 PM
someone972
Aug 30, 2015 12:52 AM
