Is a 700R-4 to a T-5 swap worth it?
Old Jan 28, 2001 | 06:24 PM
Tom Keliher's Avatar
HELL YEAH!
FORMULA 350 TK
Southern California 3rd Generation F-Body OrganizationŠ
Old Jan 28, 2001 | 06:28 PM
CamaroMike's Avatar
Real cute TOM!
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Jan 28, 2001 | 08:16 PM
MrJ's Avatar
MrJ
have you driven it yet? I remember when Jester did his T-5 swap, he told me that he had a mile long 'stiffy' the first time he drove it.
if my 700 takes a **** again, I'm going
T-5... no doubt about it.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
Old Jan 28, 2001 | 08:55 PM
Yes, I drove it last Tuesday night for the first time. I am still finishing up the interior, but the car is fully driveable and I have taken it out 3 times so far, today for the longest stretch, on then freeway, etc. It rocks! It is so much fun, to be driving my same car, but now with a stick.
I know the woody feeling, I have been having trouble seeing around the object in my line of vision
FORMULA 350 TK
Old Jan 30, 2001 | 10:11 PM
zerogauge's Avatar
can the T-5 be built to take horsepower from a V8? say 350HP
anyone do this to a T-5? How much did it cost and how hard was it? I hear rebuilding a manual is alot easier than rebuilding a automatic.
i ask because i dont want to have to switch transmissions(take out clutch pedal and switch consoles and all that shiat) if I dont have too and a T-5 will hold up(if worked over correctly).
Old Feb 2, 2001 | 01:49 AM
IROCZteady's Avatar
Hey Tom, I'm almost there myself. I've got the clutch/brake pedal installed as well as the hydraulic clutch assembly. I would have been done if I could only remove the 6 bellhousing bolts - it's just on too tight. Anyway, I wanted to ask you in advance how you wired the neutral safety switch. Do I just splice the purple and yellow wire from the automatic wire harness and hook it up to either the purple or green wire of the neutral safety switch mounted to the clutch pedal? For the back-up light switch, how did you wire it? Thanks!
Old Feb 2, 2001 | 02:33 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Gee, and I went through all the trouble of taking the Nash out of my car and putting the 700R4 back in.
Old Feb 2, 2001 | 08:29 PM
On the wiring connector that used to go on the auto shift selector I just ran a jumper between the two park wires. I made a harness, and also ran a jumper from that connector down to the back up switch on the tranny.
For the clutch start switch, since the switch I had was the old style and the new style can't be grafted onto my pedals, I just bypassed it. I ran a jumper between the yellow and purple wire at the steering column.
FORMULA 350 TK
Old Feb 5, 2001 | 08:15 PM
IROCZteady's Avatar
Thanks, Tom!
Street Lethal
Apr 30, 2019 12:14 PM
bellez77
Sep 5, 2015 08:39 PM
midge54
Sep 2, 2015 06:27 PM
lt1z350
Aug 28, 2015 05:57 AM
Cacike
Aug 27, 2015 05:10 PM
