Resurfacing my flywheel
Old Feb 6, 2001 | 11:53 AM
cfabe's Avatar
Just ordered a new RAM clutch, which comes with a 5 year/50,000 mile warranty, but to validate the warranty I must have the flywheel resurfaced. Where can this be done and how much should I expect it to cost? I'm in northeast ohio if anyone has a place to reccomend. Do I have to have it resurfaced? What are the consequences if I dont?
82 T/A 305/TH350; soon to be 350/T-5
Old Feb 6, 2001 | 01:01 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
I paid 35 bucks to have mine done,you should always resurface with a new cltuch disc IMO..
Where did you get ur clutch and how much was it?? Thanks Kevin
Old Feb 6, 2001 | 01:04 PM
JeffT's Avatar
Car: 1991 Z28
Check your local autoparts stores. If you have a NAPA near by they should be able to do it for somewhere around $20-$40. No, you don't have to resurface it but expect clutch chatter and premature disc wear.
Old Feb 6, 2001 | 02:43 PM
badbird88's Avatar
make sure they only take off just enough to get any high spots out. Sometimes they will grind it down a set amount no matter how much it really needs. If you ever go below the tolerance thickness of the flywheel you will have major clutch chatter and either have to buy spacers or get a new flywheel as I had to do.
1988 TA 300+hp 350 w/ TBI and Holley TB unit, Holley projection intake,
WC T-5, 3.42 gears w/ Auburn posi. MSD 6A, edelbrock TES headers, dynomax 3" cat and cat-back system, ACCEL coil, polyurethane bushings all around, aluminum driveshaft, Mr. Gasket open air cleaner.
1993 S-10 w/ 4.3L V6 TBI, slightly bigger cam, Mild polish job and 3 angle valve job on heads, Edlebrock TES headers, Dynomax cat back, MSD 6A, ADS chip
2000 Kawasaki KX 125
Old Feb 6, 2001 | 02:44 PM
badbird88's Avatar
double post..oops
[This message has been edited by badbird88 (edited February 06, 2001).]
Old Feb 6, 2001 | 03:39 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
Whoa I didn't know RAM has a warranty! My disc blew up after two summers of driving! I just replaced it and moved on. DANG!
Old Feb 8, 2001 | 11:23 AM
82z's Avatar
82z
You have to resurface the flywheel so it doesn't eat up the new disc. Check out your local auto parts stores to see if they will do it.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Bubbajones_ya
Jul 6, 2024 08:32 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
