B&M Megashifter not ratcheting
Old Oct 17, 2008 | 06:05 PM
Bernsdorfz28's Avatar
I have a B&M Megashifter attached to a 700r4 tranny in my camaro which is conected to a small block 350. This shifter is suppose to rachet from drive down into first, but will not do so, it makes the rachet motion but does not shift down unless i hold pressure on the closest inside plate to the driver's seat. Once down in first it rachets up perfectly fine. I checked the cable and the cable is fine, could someone help me with this problem.
Old Oct 17, 2008 | 07:38 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Re: B&M Megashifter not ratcheting
check it again you have to adjust those two nuts on the shifter cable going back between park and 1st to check
Old Oct 17, 2008 | 09:24 PM
Yea its actually fine i believe that there is something inside the shifting mechanism thats screwed up possibly a spring or something. I could tear it all apart but i just wanted to see if anyone has this problem that knew a quick way to fix it. Thanks though
Old Oct 17, 2008 | 10:27 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
i ran into the same prob it was the cable it needed to be adjusted. i bought a new cable and never had the prob again
Old Oct 19, 2008 | 07:51 AM
murd450's Avatar
Car: 83 Z28
Axle/Gears: 4:11:1
sounds more like the spring in the shifter you should be abel to get a spring kit at youre loacal speed shop , the one in my 87mc ss drag car did the same thing and it was a spring ,if it was a cabel it wouldent go int any gear and you would know if it was broken when you have to lay on the groung to put it into park!!!!! but when you do this ,if it hapens ,make shure to do it with 2 people ,so you dont get run over!!!!
ASE cert auto tech!!TEAM ASE RACING!! There is a fine line between crazy and stupid !!! what side of the line are you on???
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
Fox118
Sep 12, 2015 09:29 PM
WickedBowtie
Sep 11, 2015 11:24 PM
jayman350
Aftermarket Product Review
May 18, 2001 08:23 PM
Buck Mustard
Mar 23, 2001 03:18 PM
