what do I need to do in order for a 700R4 to shift at 6500
Car: 89 Formula T-Top
Engine: 388 MiniramII
at WOT I want the trans to shift at 6500 instead of the stock 5000. Is this controlled by just replacing the governor? What do I need to get?
'89 Formula 383 TPI
'89 Formula 383 TPI
why don't you just manually shift it whenever you want? I don't quite understand why you'd want it done automatically, but
if you want it to wait later to shift automatically then you just simply remove weights from your governor (nothing at all to buy). But I have to warn you that you may not be happy at all with street drivability with it set like that.
I use the stock weights from an 86TPI car on my governor and just manually shift when I'm racing. It has perfect drivability like that.
hope this helps,
*I do custom performance mods on Edlebrock Performer carburetors (dualplane intake mods in the works),
White 1986 Irocz, 305/383 with Edlebrock Performer-RPM intake and Performer #1407 carburetor, +110hp shot of crack, 700R-4 tranny, 3.25:1 rear, Mcreary Road-Stars, SLP-stainless 1.75" shortie headers & Y-pipe, single 3" Borla exhaust, Linginfelter-TPI camshaft part number 74216 pulls 17" vacuum solid. Cam specs 213/219 @.050 114-LSA, .462/.470 lift @1.5:1 ratio. MSD-6AL, billet distributor, multi-retard, blaster-3 coil, and RPM switch.
N/A runs 10.9 @124,
Crack-runs 10.3 @135
haven't run at track since Oct-99
hope this helps,
N/A runs 10.9 @124,
Car: 82 camaro SC
I agree, shift in manually. I have mine set-up to shift pretty early so that my wife can drive it around town without barking the tires. When I drive in hard, I just hold it in gear.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
82camaro
so the governor is what controls the shifts though, right? A shift kit just changes the line pressure for the shifts making it shift quicker. Is this right?
'89 Formula 383 TPI
'89 Formula 383 TPI
If you want the transmission to shift automatically at 6,500 rpm (in drive on the selector), this can be done but with some work. First try the lightest governor and see where you are at. Second, you will have to change springs in the governor & the shift timing springs on the 1-2. 2-3, & 3-4 shift timing valves. This can be quite an effort, but could be worth it if you are a serious bracket racer. If you have any questions call me at 800 7763288 Mon-Sat 10-6 PST and I will try to help.
Glad Too Help!!!
Glad Too Help!!!
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
