type FA in a 700R4
Old Oct 19, 2008 | 10:45 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
type FA in a 700R4
It was recommended that I put type FA fluid in my 700R4, and I'm looking for other opinions about it. I was told that it would make it shift better. Any advice? Has anyone else done it?
Old Oct 20, 2008 | 12:03 AM
performabuilt's Avatar
Re: type FA in a 700R4
I have used this in the 700r4 and had no issues with it
Old Oct 20, 2008 | 08:08 AM
Pro Built Automatics's Avatar
From having 30+ years in doing this, I never suggest you use Type "F" fluid in any 700R4/4L60E. The type "F" fluid was designed to be used with Asbestos type of clutches. They have not been in use since 1977. Since then Ford and GM went with a Dexron type of fluid to be used with the paper type of clutches that were being used from this point. The Type "F" fluid does not have the holding capabilities of the Dexron fluid in dynamic applications. That is it does not hold as well on a "shifting" application. This is where it would be needed the most. I have seen this personally, and from Borg Warner, Raybestos, and Alto have seen this also from there dyno tests. Dana
Old Oct 20, 2008 | 06:58 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Thanks, thats solid sounding advice. I returned the type FA and bought the correct fluid.
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
bjpotter
Oct 4, 2015 07:48 PM
92projectcamaro
Sep 29, 2015 07:07 PM
6998poncho
Sep 25, 2015 02:56 PM
