GM part #s for hi-perf 700R4?
Old Oct 21, 2008 | 04:50 AM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
anybody know the GM part numbers for the 5-pinion planetaries, HD sun shell, drum, sprag, etc that (I think) are used in the 4L65E (e.g. Escalade etc), that are backwards compatible with the 700R4?
I remember reading somewhere that if you're rebuilding a 700R4 and want to increase its capability, there were some newer GM "hard parts" used in higher-capacity 4L60E's, 4L65E's that are backward compatible. I think these are the same parts sold by some of the aftermarket trans vendors, but was wondering if somebody had the GM part numbers?
Thanks!
Old Oct 22, 2008 | 04:03 AM
Pro Built Automatics's Avatar
Re: GM part #s for hi-perf 700R4?
I do not know the part numbers, but save your money as the 4 pinion planetaries hold up fine. I use them in all of my nine and ten second builds, and I have never had one break.
Old Oct 22, 2008 | 02:04 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
I usually put 5 pinions in when i rebuild them because i had a 4 pinion one come apart in my car that just has a 305 with tpi on top. not that its a normal thing, but it makes me feel better, and i had to buy one anyway. but anyway I'd just talk to pro built and get everything from there and have it chryo'd and the whole 9 yards it's worth it
loud91rs
Oct 5, 2015 10:05 PM
Dragonsys
Sep 25, 2015 03:51 PM
6998poncho
Sep 25, 2015 02:56 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
HikoriYami
Sep 21, 2015 07:11 PM
