TransGo Reprogramming Kit TH700
Old Oct 23, 2008 | 10:37 AM
88´TransAM's Avatar
Car: TransAM
Engine: 355SBC
Transmission: TH700R4
I was looking for a good shift kit to upgrade my th700r4. Now, I found the
TransGo Reprogramming Kit. Is this a good upgrade for my transmission ? What do you think about this one ?
Old Oct 23, 2008 | 10:57 AM
skinny z's Avatar
Re: TransGo Reprogramming Kit TH700
I've heard good things about the TransGo kit.
I've posted a question on this forum as well to see if the claims are accurate.
Old Oct 23, 2008 | 01:02 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Get the TransGo kit from Dana at ProBuilt. There are some improvements they do on them and I hear nothing but great reviews about it.
Old Oct 25, 2008 | 04:19 AM
Pro Built Automatics's Avatar
Go to https://www.700r4l60e.com/store/home.php?cat=65 and you can choose what you want from these Shift kits. If you have any questions on this, let me know? Dana
Old Nov 5, 2008 | 02:51 PM
91camarosRS's Avatar
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
hope i did not get to this post too late. look at my sig. i love it!!!! best kit i have ever really exp. i called the company and they told me what i should get. i got mine rebuilt with bigger boost valves. CORVETTE SERVOS dont waste money on jet or tci. and the 700-2 kit 700-3 is manual. the guy on the phone explained why you dont want this or that very good info. said my setup is one they put on dump trucks? roughly 450hp range. damn good for stock internals i think for a 700
Old Nov 5, 2008 | 03:49 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
which kit did you get 91camaro? Im thinking of getting one to waken this slush box up.
Old Nov 5, 2008 | 05:13 PM
88´TransAM's Avatar
Car: TransAM
Engine: 355SBC
I bought the following parts for my th700r4 :
- Masterrebuild Kit with Raybesto clutches
- Heavy Duty band
- TransGo Reprogramming Kit
- ACC Performance BossHog Nightstalker TorqueConverter 2200-2800 Stall
I hope, it´s a good choice ?!
Do you think, i should buy a corvette-servo, too ???
Old Nov 5, 2008 | 09:55 PM
skinny z's Avatar
Check out this previous post.--------------------------------------------------------------------------------
Old Nov 5, 2008 | 10:31 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Dana, my car is on the left <-----, which package would you recommend? and whats the differences ? with the prices, and will the stock torque converter be ok ?
thanks
Doug
Old Nov 6, 2008 | 05:04 PM
I need to know what is done to the motor (If anything), what rear end gear ratio?, what torque converter do you plan on using? what is the intent of the vehicle? and anything else you think I should know? The more information I have, the better the matchup. Dana
Old Nov 6, 2008 | 06:43 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
only thing ive done to motor are just small bolt on's like open air element, msd wifes, cap, irridium plugs, flow master exhaust.
Its gonna be mostly for the street, maybe the strip once in a while
it has the 2.73 stock rear, and stock torque converter which is 12" ???
eventually i plan on doing heads, and motor work.
Old Nov 7, 2008 | 01:20 AM
The Street/Strip rebuild kit will be more than enough for what you want it to do. Do you plan on staying with the stock torque converter? Dana
Old Nov 7, 2008 | 11:42 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
For now the converter will be stock when i can wrangle up the 300+ for a new TC i might, but heads look more appealing lol,
So will these shift kits destroy the stock TC ?
Should i wait till i can get the TC and do your shift kit at that time ?
and to make sure this is the one right ?
TransGo 700R4 Street/Strip Shift Kit 1988-1993 w/Accumulator Pistons w/Seals, Pins & Corvette Servo
Part Number: TGSSSK70088+ACC+CVS
This "modified" TransGo Performance Shift Kit is for 1988 & later 700R4's. Offers smooth part throttle shifts, shifts get firmer with more throttle. 10" or smaller diameter torque converter recommended. I use this kit in all of my Performance transmission build ups. See full description.
Old Nov 16, 2008 | 08:19 AM
No, the Shift kits will not destroy the torque converter. And my Shift kits will be even easier on the whole driveline. As long as I know which TC you are going to use, I will setup the Shift kit accordingly. Dana
1Aauto
Sponsored Vendors
Feb 8, 2017 03:09 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
italiano67
Sep 22, 2015 08:42 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
