How much lucas oil do I use?
Old Oct 23, 2008 | 05:02 PM
JCL91TRANSAM's Avatar
Car: 91 Trans Am
Engine: 355 l98 mini ram
Axle/Gears: stock10 bolt 3:23 gears
If I am using Lucas oil for my for my 10 bolt rear end how many quarts do I use? Lucas already has the additive in it. When I searched i found someone saying to use 2 quarts plus the additive so I am just wondering how many quarts that adds up to? Thanks
Old Oct 23, 2008 | 05:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: How much lucas oil do I use?
Use however much it takes to fill it.
Old Oct 23, 2008 | 05:34 PM
Car: 91 Trans Am
So far there is 4 quarts in there and that almost seems like to much.
Old Oct 23, 2008 | 05:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You're filling it to the bottom of the fill plug hole?
Old Oct 23, 2008 | 05:39 PM
Car: 91 Trans Am
Yes those were my intentions but it just seems to keep taking in oil??? Something doesnt seem right!
Old Oct 23, 2008 | 06:45 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Most automotive diffs take 2-3 liters/quarts
You are filling through the plug on the side of the housing?
Old Oct 23, 2008 | 06:52 PM
Car: 91 Trans Am
Yes I am filling through the plug on the side of the housing. Is it OK to run it with 4 quarts or should I take some out.
Old Oct 24, 2008 | 09:59 PM
Car: 91 Trans Am
So what do you guys think, should I drain a quart out on my rear end to make it 3 quarts or should I leave the 4 quarts in there? I cant think of anything bad happening with 4 quarts of oil and it never over flowed out of the fill plug so maybe the rear end can hold 4 quarts. I know nothing about rear ends by the way!
Old Oct 24, 2008 | 10:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's not possible to overfill it.
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
Numbah-1
Oct 2, 2015 08:27 AM
meeklay812
Oct 1, 2015 03:46 PM
