Tranny Fluid?
Old Oct 24, 2008 | 04:30 PM
Dennis-Z28's Avatar
Car: 1991 Z28 Convertible
Transmission: 5-speed
Axle/Gears: 10 bolt, 3.08
Tranny Fluid?
This is a stupid question for anybody that knows the answer but...
When you remove the engine you disconnect the tranny at the large end of the bell housing? and when you do is there any tranny fluid or other fluid that would leak out when doing so? I have obviously never done this and assume it is dry since the clutch can 'burn' and it smells when doing so but I wanted to ask. Reason for asking is I wanted to get my T-5 re-done with new gaskets and fluid but no sense if the fluid leaks during engine removal because I want to get the engine done in a half year or so.
Old Oct 24, 2008 | 04:36 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Tranny Fluid?
the clutch burning has nothing to do with the gear oil, it does not come in contact with the clutch.
the trans is pretty much sealed, though oil can run out the end, where the driveshaft yoke slides in, if you tilt the trans rearward.
Old Oct 24, 2008 | 05:26 PM
Xlr8torZ28's Avatar
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
Re: Tranny Fluid?
I always pull mine out with the driveshaft still stuck in it, to prevent it from draining out. They also take automatic tranny fluid... I always get synthetic
Old Oct 27, 2008 | 03:08 PM
Dennis-Z28's Avatar
Re: Tranny Fluid?
The leak I wanted fixed was throught the gearing in the electronic speed sensor (not the O-ring). I am having a hard time finding one of these, where is a good place to look? They are discontinued by GM.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
HoosierinWA
Oct 7, 2015 10:15 AM
bjpotter
Oct 4, 2015 07:48 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
