'91 1LE Alum DS and '97 T56??
Old Feb 16, 2001 | 04:18 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
I'm pretty sure I can use my 1LE DS with my new T56, but what do I use for a front u-joint? I can't use my T5 tailshaft on the T56 can I? If not, what do I do... use the T56 tail and the '91 DS with a certain u-joint? TIA
'91 GTA:
www.fbody.com/members/91WS6GTA
Old Feb 16, 2001 | 06:55 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
A T5 driveshaft is interchangeable with a T56 driveshaft. It'll also fit 700R4 or 4L60E automatics. You shouldnt have any problems, its a direct swap.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Feb 16, 2001 | 11:47 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Am I getting this right? I can use my DS and T5 tailshaft in the T56. I knew I could use the DS, but wasn't sure on my tailshaft. THANKS
'91 GTA:
Old Feb 17, 2001 | 01:50 AM
Kevin91Z's Avatar
Why would you want to use the T5 tailshaft? Doesnt your T56 have one?
Old Feb 17, 2001 | 07:37 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Yes it will have one, but I was wanting to know what u-joint to use with my old DS and the T56's tailshaft. You know what I mean? Is it the same ujoint that my car uses now? THANKS
'91 GTA:
Old Feb 17, 2001 | 09:17 AM
JIMS406RS's Avatar
all you have to do is slide your old ds right into the tailshaft of the t56, they are splined exactly the same, you change nothing
91 RS
HOTCHKISS LCA'S PANHARD AND SPRINGS.
ALL URETHANE BUSHED
SUSPENSION TECHNIQUES SWAYBARS
SUBFRAME CONNECTORS
SPOHN TORQUE ARM
KYB'S
WHITE FACE GAUGES
COWL HOOD
92 Z28 SPOILER, GRILL AND FOG LAMPS
ADMIRAL BLUE
T-56
3.73'S L/S
SPOHN LCA BRACKETS
406 DFI
SUPER RAM
AFR 190
COMP CUSTOM CAM....
Old Feb 18, 2001 | 01:23 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
MAN I'M RETARDED!!! I meant the yoke on the tailshaft of the T56... NOT the tailshaft itself. SORRY! Yes, I'll just slide my front yoke and DS into the T56. Thanks and sorry again! Later
'91 GTA:
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
