T5 need help asap
Old Oct 28, 2008 | 05:20 PM
Seanmay1's Avatar
Car: 89 Firbird Formula WS6
Engine: TPI 305
Transmission: T 5
Axle/Gears: 3.45 Posi 9 bolt
T5 need help asap
was going to change the fluid, got the old fluid out and the fill plug is stripped and wont come out, i got the shifter off to add fluid, but have no way to know if its full since i can't get the top plug out. I think i remember my mustang took around 3.5 quarts. Is the t5 the same in a firebird? Would 3.5 quarts be fine for this one? I hope u guys can give me a answer in the next few minutes, i have to put the car back together and go somewhere
Old Oct 28, 2008 | 11:10 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
Re: T5 need help asap
I beleive your are right. IIRC i did put about 3 or so quarts in mine. but it was on my back and having to squeeze the bottle
Old Oct 29, 2008 | 12:20 AM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
lol i had a little pump when i did it on the mustang, was gonna do it like that today, but the damn fill plug wouldn't come out. I ended up using 3.5 though, seems to be fine, still makes the noise in reverse though. But man the fluid that came out was nasty, glad i decided to change it
Old Oct 29, 2008 | 06:47 AM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Thats why you always see if you can fill it before you drain it!
Old Oct 29, 2008 | 06:52 AM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
from now on i will make sure to do that lol. I still don't see how someone could have stripped that out
Old Oct 29, 2008 | 03:13 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
had a buddy try to use the wrong wrench on mine. can't remember how it went but it was like he was trying to use metric on a sae. just a bit bigger and it was on tight.
Old Oct 29, 2008 | 03:23 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
My '84 Firebird service manual specs 2.5L/5.3 U.S. pints fluid capacity for the T5.
92GTA
Apr 9, 2016 07:39 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Brother Al
Oct 14, 2015 06:39 AM
92projectcamaro
Sep 24, 2015 08:09 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
