Stainless, Aluminum, or Titanium Wheel Studs???
Old Oct 28, 2008 | 03:55 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Anyone ever used or know where I could get some press in style lug studs? 7/16 diameter and non-ferrous (not magnetic)
we are using traction control on our FSAE car and cannot find a lug stud that will not interfer with our Hall Effect sensors.
Anyhelp would be appreciated.
Old Oct 28, 2008 | 04:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Stainless, Aluminum, or Titanium Wheel Studs???
I'd think that a little signal processing should fix your problem.
Old Oct 29, 2008 | 08:23 AM
3rdgenmaro's Avatar
Car: 88 IROC
are you refering to filtering out the signal from it? I can see how that would be pretty easy if it was at a higher frequency, but it is the same signal that comes from the trigger wheel. What will happen is that everytime the stud rotates by it will trigger before it is supposed to
Old Oct 29, 2008 | 08:54 AM
big gear head's Avatar
All of those materials that you listed are going to be weaker than the steel studs, except maybe the titanium. I'll have to look up the strength of that one.
Old Oct 29, 2008 | 01:21 PM
3rdgenmaro's Avatar
Car: 88 IROC
right, lug load calculations will have to be run and analized.
Stainless is brittle, aluminum is weak. They are just a shot in the dark.
Titanium i know they make, but the smallest I have found is 5/8.
These aint for the average drag or street car. Alot smaller scale. Restricted Honda F4I. turbocharged 600cc with a 19mm restriction on E-85. 450lb
http://i513.photobucket.com/albums/t...oost_Steps.jpg
http://i513.photobucket.com/albums/t...*games/772.jpg
Old Oct 29, 2008 | 04:34 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Either redesign your tone wheel, or just use the lugs as the trigger signal.
1992rs/ss
16
Jan 28, 2016 09:58 PM
gixxer92
Sep 1, 2015 04:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
